Post by turbo23240sx on Jul 6, 2009 0:40:49 GMT -5
If built properly with the sonax servo covers, upgraded clutches, boost valve, shift kit etc can an A4LD be built to handle 350ish hp ? I have a spare that i can have my trans guy build cheap while my delayed shifting one holds out. Or should i put in my C4 and call it done? I really like the lockup and overdrive though.
Post by Stinger on Jul 6, 2009 15:41:58 GMT -5
It should be ok at that power level if you also run a large trans cooler. Heat is the biggest thing that kills those transmissions.
Post by turbo23240sx on Jul 6, 2009 18:52:54 GMT -5
Thanks stinger for the reply. I am looking for a 4.0 ranger trans to start with then upgrade it.
Post by Matt Culpepper 2300gearjammer on Jul 8, 2009 0:38:40 GMT -5
does a 4.0 ranger have the right bellhousing? I was under the impression that an A4LD was a one piece case meaning the bell was made together. Correct me if I'm wrong because I don't think I have any left to go out and look at.
Post by turbo23240sx on Jul 8, 2009 18:54:30 GMT -5
Matt the bell is removable like a c4. I just need to swap my 2.3 bell and it will bolt right in, except i will have to change the output shaft and tailshaft extension since the one i found is from a four wheel drive exploder.
