Post by matt2buck on Aug 23, 2015 10:25:34 GMT -5
Header to turbo studs keep coming lose.What's the size and thread count? Going to try better studs.Is anyone one else having this problem? Thanks
Post by Stinger on Aug 23, 2015 10:43:58 GMT -5
They are 10mm x 1.5 Class 12.9.
The "simple" solution is to tack weld the studs on the bottom side of the flange with a small tack. That way it can't come loose unless you grind the tack weld off.
Post by matt2buck on Aug 23, 2015 14:50:59 GMT -5
Thanks I will do that
