Post by nmanville on Jul 14, 2009 17:08:58 GMT -5
I have spark and fuel, i think, the spark plugs smell of gas when i take them out but i cant see any in the cylender. i cranks slow and will not start. anybody have any ideas?
Post by 93turbopony on Jul 14, 2009 20:57:24 GMT -5
make sure your starter isn't bad, also make sure timing is set corectly
Post by nmanville on Jul 14, 2009 21:53:34 GMT -5
worked on it sone more. There is fuel and spark. It back fires every now and then but won't start. I am putting new plugs in it. Any other ideas?
Post by Stinger on Jul 14, 2009 23:26:52 GMT -5
Backfire indicates either the plug wires are out of order or timing is WAY off.
Post by nmanville on Jul 15, 2009 18:54:05 GMT -5
Ok, I have spark and fuel. I reset the distributor and checked the timing. Now I have nothing. Plug wires are in the right order and everything.
Post by nmanville on Jul 15, 2009 22:45:48 GMT -5
I figured it out. It was the advance on the distributor. Thanks for the help
Post by 93stangnow23t on Jul 16, 2009 0:53:00 GMT -5
so is your turbo setup up and running?
Post by nmanville on Jul 16, 2009 20:19:10 GMT -5
Yep, I just need a gasket for the oil return and I need to block off the EGR. When I start it, it will go up to 4000 rpm. I am pretty sure that is just because there is no EGR. Other than that yes.
