bobbyk10
Boosting 10 psi
Finishing the 2.3 T swap
Post by bobbyk10 on Oct 10, 2015 8:45:30 GMT -5
I have a lb3 computer. My question is will that harness plug right into everything with no problems because I don't want to have to do much wiring.
Thanks in advance for the help.
Post by Stinger on Oct 11, 2015 17:24:28 GMT -5
No idea what vehicle you have so I have no way to answer your question.
bobbyk10
Boosting 10 psi
Post by bobbyk10 on Oct 12, 2015 9:50:02 GMT -5
91 foxbody with originally a 2 3 na, I'm asking about buying the $500 harness on stinger performance
Post by Stinger on Oct 12, 2015 11:29:13 GMT -5
It will plug into the turbo engine and ECU. The directions are linked in the listing on the site and it shows you what it takes to connect it to the car.
Post by 1988turbocp on Mar 17, 2016 11:53:01 GMT -5
I have an 88 Turbo CP. Is this harness set up for single or dual fans? Thanks!
Post by Stinger on Mar 17, 2016 15:03:47 GMT -5
It is set up to control a single fan, or have both fans come on at the same time.
