Post by coreydaniel on Jul 16, 2009 21:15:21 GMT -5
I took my car to the dyno tonight. Here is the setup. Stock 2.3 shortblock, stock head, ranger roller cam, E6, Holset hy35, custom upper with 75mm throttle body. 255 fuel pump, 14deg. base timing, 45psi fuel pressure, and 20psi boost.
The peak hp was 240 at around 4700rpm and 318ft/lbs at around 3600rpm. The air fuel stayed around 12.3 and 12.8
Post by coreydaniel on Jul 16, 2009 21:34:33 GMT -5
Correction, the AFR was not 12.3 or 12.8 i was looking at the wrong sheet. The AFR never got above 11.2
Post by denz on Jul 16, 2009 22:06:48 GMT -5
congratulations man 318 tq at 3600 bet thats a fun car to drive, where did you dyno it at?
Post by Stinger on Jul 16, 2009 23:18:09 GMT -5
Not too bad...a little porting and a performance cam and it would be an animal.
Post by coreydaniel on Jul 17, 2009 17:02:59 GMT -5
yeah ive got a spare head, intake and manifold and im going to port everything i can. I was also looking into a boport cam, anyone have any opinions on them and which one is best? o
Post by Stinger on Jul 17, 2009 21:03:35 GMT -5
I run a Boport cam, the "best" would depend on which description best fits your needs.
Post by coreydaniel on Jul 18, 2009 12:21:30 GMT -5
I like the decription of the 1.5 version. I think i will try it. The RPM range sounds about right since my turbo doesnt really start spooling until about 3k.
Post by Stinger on Jul 18, 2009 14:46:33 GMT -5
Sounds like a plan. I'm running a stg3 but I'm also trying to make 415+rwhp on pump gas.
Post by coreydaniel on Jul 18, 2009 17:25:25 GMT -5
yeah im going for 300rwhp, and im only 60 horsepower away from my goal, so i shouldnt have to make too many changes. I could always put a 75 shot on there if i wanted.
Post by Stinger on Jul 18, 2009 19:12:29 GMT -5
Shouldn't be too hard...cam should be good for 30hp or so...what intercooler and exhaust?
Post by coreydaniel on Jul 18, 2009 21:51:09 GMT -5
i made my exhaust, i have access to a macine shop, sho i made my own flange and 3in down pipe for the holset. Im running a spearco front mount and 2.5 in IC piping
Post by Stinger on Jul 18, 2009 23:21:45 GMT -5
That should do...make sure the head is sealing up, they rarely do in stock (used) form.
Post by coreydaniel on Jul 18, 2009 23:30:13 GMT -5
the head i am porting has had a recent valve job, so hopefully it will be ok
Post by thewrench3 on Jul 19, 2009 9:35:47 GMT -5
I like this combination. Where are you getting the holeset turbo from? Does it bolt on to the t-3 exh. flange? I'm thinking this maybe a better set-up for my bracket car.
Post by coreydaniel on Jul 19, 2009 11:55:57 GMT -5
the holset is a hy35w from a late model Dodge truck. The exhaust flanges are no tthe same, i have seen the flanges on ebay. I made my own from a scrap piece of thick flat steel.
