Post by dizzle96 on Jul 28, 2009 8:36:32 GMT -5
Vehicle:
1984 Svo
2.3 Turbo
5 speed manual
Blue primer exterior
Charcoal cloth interior
Power windows
Odometer reads 26,xxx(im assuming 126,xxx)
Recently replaced:
New radiator
New stinger performance coolant tubes
Newer clutch
New valve cover gasket
New w/p
New t/stat
New head gasket
New rear freeze plug
New brakes
New shocks
New struts
New springs
New o2 sensor
New plugs
New wires
New cap&rotor
All fluids have just been changed including diff!
Mods:
8.8 rear end swap
3.73 gear
3in downpipe
Straight pipe 2.5in exhaust,dumped before axle(rather loud)
Gillis manual boost controller
Forced4 hard tube
Bosch bypass valve
Cone filter
Timing advanced
16in waffle star rims
Boost and a/f gauge mounted in a-pillar pod.
The good:
The car runs excellent,drives great,no issues. Doesn't leak or burn oil or any fluids for that matter. Turbo spools fine and pulls hard. Trans and clutch work great,no grinds or slips. Rearend is quiet as a church mouse. The car has no rott anywhere! Pans,a-pillars,strut towers are all clean! Doors even shut with no effort. Car is dead solid!!! I can't stress that enough!
The bad:
Body is in a ugly blue primer,needs paint. Rear hatch has a dent by the roof(hatch was replaced by old owner). Shifter knob and steering wheel are starting to peel as usual. The a/c was removed by old owner. Radio does not work(no idea why). Heater blower makes some funny noises every once in a while. Headlights and corner lights are foggy. Dash pad is cracked. That's about it.
I've come into some personal problems and need to sell this car ASAP! NO TRADES! Cash only. Clear title in hand!
$3200.00 o.b.o,cash talks and bullnuts walks!
Email with any interest,questions,etc...
Dalemanley@tmail.com
1984 Svo
2.3 Turbo
5 speed manual
Power windows
Recently replaced:
New radiator
Newer clutch
New w/p
New t/stat
New head gasket
New brakes
New shocks
New struts
New springs
New o2 sensor
New plugs
New wires
New cap&rotor
Mods:
8.8 rear end swap
3.73 gear
3in downpipe
Forced4 hard tube
Bosch bypass valve
Cone filter
Timing advanced
The good:
The bad:
