Post by lightnings2 on May 15, 2018 2:31:47 GMT -5
My mistake I took someones opinion that could not be confermend. Sorry that took that information as fact. I'm still interested in the new Pimpxs with the trans control. Please let me know when it becomes avalible & the pricing.
Post by Stinger on May 15, 2018 15:12:49 GMT -5
I'm not saying their opinion was invalid, I just can't respond to it without knowing what was said.
Post by lightnings2 on May 15, 2018 18:14:22 GMT -5
There is a thread on NLOC in the Gen 1 lightning form about installing a PiMPxs ecu - questions were asked about the ecu being able to control the trans. Is this Shannon?
Post by Stinger on May 15, 2018 21:59:38 GMT -5
Yes, that's me.
Post by lightnings2 on May 16, 2018 18:30:55 GMT -5
On NLOC I'm Blitsen2. Could there be a possible group buy - and how many units would it take to make that happen?
Post by Stinger on May 16, 2018 20:01:15 GMT -5
I assume you've seen my replies over there?
Possibly. Have to think about it. Gotta get the new one finished first.
Post by lightnings2 on May 17, 2018 2:42:22 GMT -5
Yes.I've been following along.
Post by lightnings2 on Jun 6, 2018 1:18:50 GMT -5
Shannon, Would installing a knock sensor help PiMPxs with tuning and spark control?
Post by Stinger on Jun 6, 2018 1:35:43 GMT -5
If you know how to tune and utilize a knock sensor and have a knock sensitive/octane limited engine setup it might. With that said we've only had two customers ever decide they "needed" it.
Post by lightnings2 on Jun 15, 2018 4:51:39 GMT -5
Will there be a problem with your set-up for smoging in Calif. The truck should run clean so I don't it should be. Just asking?
xrjoe
Boosting 10 psi
Post by xrjoe on Jun 15, 2018 12:23:25 GMT -5
Will there be a problem with your set-up for smoging in Calif. The truck should run clean so I don't it should be. Just asking? Do you need to retain functioning EGR?
Post by Stinger on Jun 15, 2018 12:38:53 GMT -5
Will there be a problem with your set-up for smoging in Calif. The truck should run clean so I don't it should be. Just asking? The sniffer test is fine as you can adjust things to control emissions. If they do a code scan or test for functioning emissions equipment as part of the test it won't pass.
Post by lightnings2 on Jun 19, 2018 5:49:07 GMT -5
Yes I will need to retain egr function.
Post by Stinger on Jun 19, 2018 9:58:09 GMT -5
It's not a "normal" feature but a programmable input can mimic EGR function.
Post by lightnings2 on Jul 8, 2018 3:50:05 GMT -5
Shanon, Any progress with the PiMPxs with trans control for the trucks?
