brsvo
Post by brsvo on Mar 5, 2016 8:36:05 GMT -5
Hi Bruce here. I have an 86 SVO with 3" DP and dual 2 1/2 inch mufflers. My set up needs a new Y pipe (original is custom and not as wide as stock) I added a Watt's link and the width is not sufficient anymore. Will the mid pipe reach all the way from the DP to the Y? I want to delete my cat and need to replace the Y in mine. If so how do I order just the Y and Mid pipe? Also I bought a flex section for the new set-up where should I put that? Thanks Bruce
Post by Stinger on Mar 6, 2016 22:27:13 GMT -5
Our midpipe/y-pipe setup goes from the end of the downpipe to the inlet of the mufflers. The option to buy those items without the downpipe is available in the "header parts" section of the site. Flex can go where the cat originally was.
brsvo
Post by brsvo on Mar 7, 2016 6:15:12 GMT -5
How much and how long to get the mid and Y in stainless? Thanks, Bruce
Post by Stinger on Mar 7, 2016 11:18:54 GMT -5
$350 and it's special order so it would take about 2 weeks.
brsvo
Post by brsvo on Mar 26, 2016 11:04:01 GMT -5
Ordered and received the mid and y. Thanks, now I have a question about the offset of your muffler openings. What is it? The y I got from you is 2" narrower than mine and I hoped it would be wider than mine. I should have asked before ordering. I need to move the tail pipes out an inch or so to clear my watts link. Thanks in advance, Bruce
Post by Stinger on Mar 26, 2016 11:48:03 GMT -5
Requires offset/offset mufflers, same as stock. You can actually put a floor jack between the pipes and push them farther apart without issue if you're needing them farther apart.
You put one leg of the y pipe under the frame of the jack, the other above lifting pad, y pipe sticking out sideways from the jack. It moves pretty easy a long ways without any issues.
