Post by turbo23240sx on Aug 8, 2009 22:02:04 GMT -5
How much timing can i run with 25-27psi non intercooled with alky injection and 112 race fuel? I am running 20* with pump fuel and it works well so far, but i am track testing it tomorrow and was wondering if i should add more timing or leave it alone?
Post by Stinger on Aug 8, 2009 22:33:43 GMT -5
More timing isn't always better. Once you reach "ideal" timing, you are only risking breaking things by adding more timing. A dyno is the ideal place to test it but a track is second best. Make a few runs to get a baseline, add a few degrees and see if it picks up mph...when the gains flatten out, back it off a few degrees.
What you "can" run and what you should run would be two different things. You may find something between 24-26 degrees to be ideal.
