Post by Stinger on Oct 20, 2016 23:46:37 GMT -5
Spartan2 Wideband o2 Sensor Controller
This is a purebred Wideband Oxygen Controller with no excess. Spartan 2 is our next generation Wideband Oxygen Sensor Controller for the Bosch LSU 4.9 Wideband Oxygen sensor.
Spartan 2 is designed with Megasquirt in mind, Megasquirt users can enjoy the most accuracy with Spartan 2 than with any other brand of Wideband Oxygen Controller through our easy to use Output Sequencer feature.
Available with and without wideband o2 sensor and gauge.
Features:
--Spartan 2 utilizes the Bosch LSU 4.9 Wideband O2 Sensor - a cost efficient Wideband O2 sensor providing 0.01 Lambda accuracy, fast response, and rated life of 60,000 miles.
--Compatible with all fuels: AFR/Lambda range, 0.68[Lambda] to 1.36[Lambda], 10[AFR] to 20[AFR] equivalent for gasoline
0.01 Lambda accuracy without the need for any calibration.
--Utilizes patent pending Binary Drive technology; no other system is more digital.
--Linear Output allows easy interfacing with gauges, fuel management systems, and data-loggers (0v = 10 AFR, 5v - 20 AFR).
--Innovative Output Sequencer feature means our Wideband O2 Controllers to have the most accurate Linear Output on the market. You can be sure that any device connected to the Linear Output will receive the most accurate AFR/Lambda signal possible. The Output Sequencer provides a dual level precision voltage signal to the Linear Output. This allows you to easily check that the AFR/Lambda seen by any device connected to the Linear Output is accurate, and if not, to generate a 2 point calibration to achieve perfect accuracy.
--Simulated Narrowband Output allows you to install a Wideband O2 Sensor in place of your Narrowband O2 sensor.
--Easy 4-wire installation for most setups
--Two-Year Warranty that is twice as long as any competing product.
--6ft Cable Length
Includes:
Spartan2 Controller
Waterproof Fuse Holder with Two 5 amp Fuses
Price: $ 75.00 - $175.00
Solid Air/Fuel Ratio Digital Gauge
Solid AFR features an attractive digital blue LED display, tinted faceplate, and cutting edge electronics for a lighting last refresh rate; all housed in high quality aluminum 52mm enclosure.
Solid AFR is compatible with Spartan2 above, as well as all 14Point7 branded Lambda controllers as well as most other major brands of Lambda controllers.
14Point7 stands behind this product with a warranty that is twice as long as any competing product. With an unrivaled 60 day money back guarantee, you can buy with confidence and know that you are getting the absolute best.
Features:
--Designed for gasoline fuel only
--52mm diameter
--3 digit blue LED display
--Tinted faceplate
--10 AFR to 20 AFR range
--0.1 AFR resolution
--Compatible with most lambda controllers
--Analog Input, 0v = 10 AFR linear to 5v = 20 AFR
--2 year warranty
Includes:
--52mm AFR gauge
--6ft power cable
--Mounting hardware; bracket, nuts, and bolts
Price: $ 50.00
Bosch LSU 4.9 Wideband o2 Sensor (Replacement)
Compatible with Spartan2 Lambda Controller and other controllers that use LSU 4.9 sensor (many other brands use the older LSU 4.2 sensor so verify before purchase). The LSU 4.9 is a cost effective Wideband O2 sensor providing 0.01 Lambda accuracy, fast response, and rated life of 60,000 miles.
Price: $ 75.00
All products can be found on this page: www.stinger-performance.com/universalparts.html
Features:
--6ft Cable Length
Includes:
Spartan2 Controller
Features:
--52mm diameter
--Tinted faceplate
--2 year warranty
Includes:
--52mm AFR gauge
--6ft power cable
Price: $ 50.00
Price: $ 75.00
