Post by reaper5lm on Aug 26, 2009 22:35:16 GMT -5
Well while I wait for my new clutch set up I was going threw the car and did some Radiator pressure testing and compression test. I found compression was fine 135psi in all 4, But I found some radiator coolant seeping out the back side corner of the driver side from between the head and block under 20psi. I know it means a new gasket. What I was wondering has anybody ever re-torqued it to get a few more passes out of it?
Post by Stinger on Aug 26, 2009 22:56:04 GMT -5
Did you retorque it initially? Either way, you can give it a shot and see what happens. Odds are if it's leaking it's already "tweaked" though and while a retorque may seal it up for a short time, it won't "fix" it.
Post by reaper5lm on Aug 27, 2009 1:22:05 GMT -5
Yes, I had retorque it once . I am just trying to buy some time so I can take back to the track on the same gasket. lol . I'll give it a try and re-test it to see if it holds up. I started looking for the Headgasket 1035. It's $50+bucks on most places any place to get it at a better price.
Post by Stinger on Aug 27, 2009 2:33:29 GMT -5
That's the price...can't find them cheaper.
Post by reaper5lm on Aug 27, 2009 2:46:31 GMT -5
I just found one 45.bucks at Autozone. WOW.. That's the best price yet...(special order of c)
Post by reaper5lm on Aug 27, 2009 2:49:20 GMT -5
How long has a stock headgasket Held for you? I have one sitting in the tool box but not to sure I want to use it.
Post by Stinger on Aug 27, 2009 11:48:55 GMT -5
We won't discuss mine...I've only got 50 miles on it since it went back together in June.
There is a guy in Colorado making 596rwhp on an 8993 (stock felpro) headgasket. He's on E85 fuel though which is very forgiving. I run the 1035 gasket.
Post by reaper5lm on Aug 27, 2009 14:16:09 GMT -5
I'll keep using the 1035 it was good to me, for about 6months of hard use. ;D No E85 setup.
Thanks,
Post by Stinger on Aug 27, 2009 19:18:28 GMT -5
There is a good chance the damage was done early on before the tune was dialed in.
Post by reaper5lm on Aug 27, 2009 21:48:33 GMT -5
Yes, that is what happened I had it jump timing on me a little while back when I was having the oil issue thew the dip and crankcase. It popped some. I just went by Pep boys and ordered the 1035 for 45. Account/ Then I went by Orielly A got 1 for 40. Employee A. I also just received the flywheel it is Nice...
Post by reaper5lm on Sept 4, 2009 17:44:59 GMT -5
Well, Today I decided to pull the head just to be on the safe side and good thing I did the gasket had blow out 2,3,4. Good thing I had all the gaskets ready. ;D (I was trying to avoid the work).lol
Post by Stinger on Sept 4, 2009 21:47:01 GMT -5
Yeah, pics you sent definitely show it's blown.
Post by reaper5lm on Sept 8, 2009 17:39:36 GMT -5
Well the NEW 1035 is in let's see how long we go on this one. ;D I also got all the stuff to Do the 2.3 clutch to 5.0 except the Aluminum spacer plate behind the flywheel. Will I need it?
Post by Stinger on Sept 8, 2009 19:45:38 GMT -5
Yes, you'll need a 5.0 aluminum spacer.
Post by reaper5lm on Sept 8, 2009 20:56:15 GMT -5
Cool, I'll continue looking.
Thanks,
