Post by win1soon on Aug 27, 2009 23:22:49 GMT -5
ok need some ideas on how to rig up a turbo drain tube i have a ihi turbo from a 88 tc but have a n/a block can i just tap the side of the oil pan? and which tube should i use? i got some empty beer cans & a sharp punch will that work? lol.
Post by Stinger on Aug 27, 2009 23:43:16 GMT -5
The factory drain location should be in the block just not tapped. You can run it to the pan and then use our header return line. Just make sure you order the line before you drill the hole in the pan so you can make sure it is in a location that allows the oil to gravity feed out of the turbo (downhill all the way). Also make sure it returns above the oil level in the pan.
Post by reaper5lm on Aug 28, 2009 19:05:16 GMT -5
That is what I did . I ran a steel braided line to the front side of the oil pan it works fine for me. The funny thing is that I have a 88T block. lol
