Post by 93stangnow23t on Aug 29, 2009 23:20:52 GMT -5
hey is the 92 wiring harness the same as a 93? if i took mine out and put a 92 in would it work with my ECU and plug ups?
Post by Stinger on Aug 29, 2009 23:45:52 GMT -5
Some wire colors are different but locations are the same. Shouldn't be any issues doing that.
Post by 93stangnow23t on Aug 29, 2009 23:52:48 GMT -5
ok well im thinking about picking up another one so i can send it to matt get the wiring done and then have all the stuff i need to do the swap without having to wait on something.
Thanx by the way.
Post by phil88turbonotch on Aug 30, 2009 2:07:06 GMT -5
what does matt charge, to do a 88 mustang to 87 turbo coupe?
Post by 93lxturbo on Aug 30, 2009 9:10:00 GMT -5
matt did my wiring harness for my 93 mustang.. hes the best.. it was not to much but the price is between you two
Post by 93stangnow23t on Aug 30, 2009 9:49:00 GMT -5
we have already talked about it but i just dont have the time right now to do the swap so im trying to get all the parts together then do it so i dont have to weight on one thing.
Post by 93lxturbo on Aug 30, 2009 10:14:36 GMT -5
i had the time i just kept fring la3 cause i suck at wiring..
Post by 93stangnow23t on Aug 30, 2009 11:09:08 GMT -5
yah thats what im afraid im going to do so im just going to dish the money out early so i dont have to spend money on another LA3 and then send the wiring out to get rewired.
Post by Stinger on Aug 30, 2009 13:28:05 GMT -5
what does matt charge, to do a 88 mustang to 87 turbo coupe? It's like 3 wires...don't even think of paying someone to do that for you. The 91-93 is much more involved so it's overwhelming for some so paying someone else to do it is more reasonable.
Post by phil88turbonotch on Aug 30, 2009 22:00:10 GMT -5
lol thanks stinger. ya i have read your article, does not seem to complicated. especially since the wiring is all out any way. i was just kinda curious, i would probably get more satisfaction from doing it myself any way..... that sounds dirty lol
Post by oneowner88lx on Sept 2, 2009 20:32:37 GMT -5
I used stinger's write up and the following write up to swap a '88 turbo coupe engine into an '88 LX 2.3. Click on the following link then click on 85 How To's scroll down then click on 2.3 turbo swap: www.flemworld.com/There are lots of diagrams and step by step instructions. You can't go wrong following these instructions. The wiring was really easy to do. One thing I did do was run a ground from the turbo compressor housing to Pin 49 to insure the O2 sensor is grounded. I used a "jumper" connector from Walmart to make the connection so I didn't have to cut the Pin 49 wire. To connect the VAM to the EGR wires I found a male connector on the tbird engine harness over on the front passenger's side that would plug into the stock mustang 2.3 EGR connector. This way I did not have to cut the mustang harness to connect the VAM wires to the EGR wires. Car runs great after the swap!
