Post by deathbypsi on Apr 16, 2017 9:25:19 GMT -5
Im putting a friends(Rod Durham} 2.3t 83 TC together right now and he bought the new PNP MS kit with the Ron Francis harness. I have everything 95% hooked up now but there is a bundle of wiring thats wrapped up on the end inside the passenger compartment that I dont remember being addressed in any instructions that were provided to me. This is the third RF harness I have installed and this is the first one to have this bundle of wires near the MS plug. The only labeled wire I recognize is one marked WLED which I believe will be for the fan relay.
Anyone have any insight to this part of the harness ?
Post by Stinger on Apr 16, 2017 14:10:21 GMT -5
They aren't used for PNP applications.
Post by deathbypsi on Apr 17, 2017 8:17:44 GMT -5
The fan wiring is in there tho, correct?
Post by Stinger on Apr 17, 2017 14:15:11 GMT -5
From the Startup Guide:
Single Fan Control Wiring and Configuration It is very easy to configure your ECU to drive a cooling fan. The “ALED” wire and associated output can be found coiled up in your harness near the Microsquirt. This wire can be easily configured to provide a ground for a fan relay. The diagram below shows how it needs to be wired. You’ll need a 5 pin relay and a 20 amp inline fuse as shown below. Note that there are two different wire sizes. The large 10 gauge wire carries a large amount of current to the fan. The smaller 18 gauge wires simply trigger the relay to turn the fan on.
Note the part I highlighted in bold.
Post by deathbypsi on Jul 5, 2017 9:29:13 GMT -5
Shannon, how do I get into the PNP forum since I have other questions about this set up? I still can not get this car to start
Post by Stinger on Jul 5, 2017 12:09:48 GMT -5
That's what premium support entails. Rod didn't choose to buy support so he'd have to do so to gain forum section access and "PiMP-like" support from Wes and I.
Post by deathbypsi on Jul 6, 2017 10:30:46 GMT -5
So if he dont pay for that there is nowhere for me to get help with this system?
Post by Stinger on Jul 6, 2017 17:02:36 GMT -5
You either buy support (and get our help) or you don't (and you are on your own). If you don't, it's like buying or building a generic Megasquirt product so the only support is via the MSextra forum. I explained this to him over the phone before he bought it and he said he didn't need support because you guys had a bunch of Megasquirt stuff already (which is fine, that's why we give the option, to offer it at a lower cost for those who have MS experience and don't want/need support).
He can purchase support at any time if it's determined it's needed.
