Post by turbopony92 on Sept 21, 2009 15:10:55 GMT -5
ok this is my last wiring question...i didn't get a resistor with my coil pigtail from the turbo coupe. so,i grabbed a coil pigtail from a 3.8 thunderbird and i'm wondering if i can use that? it looks like it is an inline resistor and it is on the negative side of the coil. would it work if i wired it inline on the positive side? or should i just get a different resistor all together? any help would be appreciated.
Post by Stinger on Sept 21, 2009 18:05:51 GMT -5
You should be fine without the resistor.
