Post by Strangeleak on Sept 22, 2009 12:10:14 GMT -5
This is a tough one. All input is helpful though. Do you think these numbers are measuring the outside diameter of the main/rod journals on the crank? Or do you think they are measuring the inside diameter of the main/rod caps assembled?
Major engine specs are .............................................2.3 Early Bore.....................................3.780 Stroke..................................3.126 Bore Spacing........................4.173 Main Journal Dia...................2.3986 Rod Journal Dia...................2.0468 Con. Rod Length..................5.2047 Crank Center to deck...........8.368 Piston pin height..................1.583
I can post the numbers from my crank if necessary.
Post by Stinger on Sept 22, 2009 13:42:37 GMT -5
I would assume it's the measurements on the crank.
Post by Strangeleak on Sept 22, 2009 15:17:15 GMT -5
Do you happen to know the tolerance amount either way. I can't seem to find that info anywhere.
Cause my main journals average 2.3952. And my Rod journals average 2.044
Post by Stinger on Sept 22, 2009 22:22:39 GMT -5
I don't have any idea.
Post by Strangeleak on Sept 23, 2009 7:51:34 GMT -5
I guess I'll just clean everything up then plastigage. As long as that comes out within tolerance I should be fine.
