Post by reaper5lm on Oct 5, 2009 22:40:17 GMT -5
I am having trouble with my Header nuts coming lose often(the ones holding the turbo down). Has any one ran across this problem?
Post by Stinger on Oct 6, 2009 0:50:15 GMT -5
Moved here for searching purposes: If you want to order them online: www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=MIA-FST-032&Category_Code=FSTIf you want to find them locally: Cummins Turbo Nuts/Studs: At your local dealer. Studs - 4920497CUM Nuts - 3818824 These are an exact match. M10 x 1.5 Also A CAT T-3 turbo gasket that is extra thick with a divider. Good for leaky manifolds. Gasket - 73C7431 You can also lock the studs in the header by either spot welding them on the bottom or using a punch to screw up the threads a bit. Doesn't matter what nuts you use if the studs can screw out of the flange.
Post by reaper5lm on Oct 6, 2009 8:54:46 GMT -5
Cool, I have spot welded the bottom of the studs. I just did this now I was looking for some better parts to hold it down. (nuts) lol...
Thank you Shannon
