Post by 93turbopony on Oct 12, 2009 17:42:35 GMT -5
i'm running the la3 and large blow thru vam, can I run 42lb injectors i want to hit 300hp, the only ones i can find are BOSCH EV1, I think the high impedance will that matter.
Post by Stinger on Oct 12, 2009 20:52:24 GMT -5
35's can support 300hp if you raise the fuel pressure to 50-55lbs base. It's the same as doing it with 42's at 45psi base or so.
You want low imp injectors if you go that route.
