Post by boosted on Oct 17, 2009 16:39:07 GMT -5
I am asking $3500 78000 original miles Turbonetics t3/t4 57mm turbo 46 lb Ford injectors 8UA ecu swap Big VAM Tokico Illumina 5 way adjustable shocks and struts All the bushings front and rear have been changed over to eighther alluminum or delrin Megabite Jr. lower control arms andf stock upper control arms Heavy duty Global west swaybar Global west caster camber plates Wilwood brake on rear 4 piston calipers with 12.125 rotors Stainless braided brake lines 2005 GT 17 inch wheels 3" down pipe and 3" all the way out the back NPR front mount intercooler Walbro 255 lph fuel pump Billet adjustable fuel pressure regulator Ford motorsport plug wires Turbo XS RFL blow off valve Borg Warner T5 Trans. Steeda tri-ax shifter w/ Hurst arm (short or long which ever you prefer) UPR clutch quadrant (2) 2 5/8 Autometer Ultralight Boost and Fuel pressure There is pics on this site: bgky.craigslist.org/cto/1423911795.htmlIf any question or want to schedule a test drive call 270-590-2842 or email me bbowles0003@kctcs.edu
