Post by fairmont on Nov 6, 2009 9:03:12 GMT -5
What about behive spring? I posted on NATO a question on Alk/Met injection and i need your advice. On blow through set-up,do you think that if i put injector before Vam it will be ok with temp sensor(wide band will be use to monitor) I was thinking that if sensor get cooler charge it would automaticaly give a rich condition meaning i could turn up the boost!
Post by Stinger on Nov 6, 2009 16:53:16 GMT -5
It's not going to add any significant fuel if it reads a cooler charge, it's just going to add timing. I don't see any benefit from injecting it before the vam but I can think of a number of problems with it (puddling in IC, eroding compressor wheel, corroding vam, loss of atomization, etc.).
Post by fairmont on Nov 9, 2009 9:32:07 GMT -5
Next question, Would it be possible to put a block plate between head and lower intake so that coolant gets deleted in the lower?
Post by Stinger on Nov 9, 2009 18:49:05 GMT -5
Yes, there have been a few people that made small batches in the past. They make them out of phenolic plastic material so it also keeps the heat of the head out of the intake. Most other materials either fail under the heat or crush when torqued down, or transfer heat.
I believe there is a 2.3 industrial application gasket that has the block off built in and can be special ordered from a parts store for like $10.
Post by Matt Culpepper 2300gearjammer on Nov 13, 2009 1:15:26 GMT -5
soooo What tires are you running?
and how far does it stall when you go to take off?
Thats a great great time. You need a damn vid with sound though. I'd like to hear it.
Post by fairmont on Nov 13, 2009 17:04:40 GMT -5
Hoosier 26x9 slicks and for take off i spool the turbo a little bit, then when lights goes down i hammer it to the floor at the last yellow light. I'm supposed to race this next Sunday Nov 15th with my first "modification",255pump and i'll put ice on intercooler.
Post by fairmont on Nov 23, 2009 21:10:48 GMT -5
Went back to race track Nov 22nd, new best of 14.08 at 94mph with 1.91 60ft.
