Post by Hueneme805 on May 24, 2018 18:50:26 GMT -5
Gonna be doing a clutch slave cylinder install due to pedal not holding pressure( bottoming out)and Looking for some info. Just mainly a proper way to bleed fluid. Can I just remove slave and install or remove master cylinder pre assemble with slave cylinder outside engine carpartment bleed unit and then install as a whole unit?
Post by Stinger on May 24, 2018 19:36:08 GMT -5
I've never done one in a TC and they are all a little different. I'm pretty sure there is an article on NATO in the FAQ/Tech section that covers it though.
