Post by bobbarker on Oct 29, 2009 14:02:05 GMT -5
Do I need to have it on the car? I pulled the header and turbo off the other day and the EGR tube was stuck and I ended up cracking it trying to get it off the intake side ... I looked around but couldn't find a thread on it. Does anyone sell a block off plate for it if it's not needed?
Post by Stinger on Oct 29, 2009 16:34:46 GMT -5
You don't need it. You can make a block off plate very easily or I think bo-port or 40bob sells one.
Post by bobbarker on Oct 29, 2009 19:23:25 GMT -5
Thanks! Are there any codes that I will encounter or running issues? Just make sure it's blocked off completely at the intake or on the back of the EGR "sensor" itself?
Post by Stinger on Oct 30, 2009 16:31:28 GMT -5
It will throw a EGR code but won't cause the check engine light to come on. Block it off on the intake and exhaust manifold port.
