Post by 79turbostang on Nov 2, 2009 22:54:19 GMT -5
OK I got a 87 2.3turbo coupe motor in m 79 mustang. I was working on trying to get the vacuum problem all worked out because i was only vacuuming 10 psi at idle... well i got that all worked out but i was fulling with my cam timing trying to get it all worked out the vacuum problem was the egr valve staying open all the time. but when this was all happing the car pull really good at 8psi but now that Ive got all the vacuum problem worked out it doesn't pull as hard.. i think the cam timing is still off but i cant seem to get it right because there is no mark Ive got the cam pointing right at the aux pulley bolt.. i set the timing with the spout off at 10 degrees btdc then when i plug the spout back in it only jumps to about 22-25 degrees.and on other thing when i run the car down the road and boost it and let off the gas push the clutch in the car dies whats this all about
Post by Stinger on Nov 3, 2009 0:13:26 GMT -5
Did you set it to 10 degrees BTDC or ATDC? It should be set to the mark above/towards the passenger side of the TDC mark, sounds like you set it to ATDC.
Post by 79turbostang on Nov 3, 2009 18:52:22 GMT -5
no its at btdc. what would make the car die after letting off the throttle
Post by 79turbostang on Nov 4, 2009 0:03:35 GMT -5
could there be a problem that i might be running a MAP sensor off a 87 2.3 n/a motor rather that a biometric pressure sensor for a 87 2.3 turbo coupe ?
Post by Stinger on Nov 4, 2009 0:04:01 GMT -5
A number of things including a dirty IAC valve, lack of vacuum, improper cam timing or ignition timing, improper TPS voltage setting, etc.
What rpm does it idle at? How much vacuum? Stock cam?
Post by 79turbostang on Nov 4, 2009 20:26:02 GMT -5
it idles around 1000 rpms its gitting about 18-20 psi of vacuum and it has the stock cam
Post by Stinger on Nov 4, 2009 23:30:38 GMT -5
I'm not convinced your ignition timing is right. It should go to the mid 30's at least at idle with the spout in.
See our tech article about setting base idle to see how to fix the problem with it dieing and such.
Post by 79turbostang on Nov 5, 2009 3:22:02 GMT -5
ya Ive been trying to get the timing set right for about a month now. i just cant get it set right well ill try fooling with it again. ill check that tech article out and see what i can dig up but i have to go to Chicago this week thanks for the help stinger ill get back to you if i still cant figure this out
Post by turbo2300 on Nov 5, 2009 10:34:52 GMT -5
i just had this problem, it didnt seem like it wanted to move much
is the throttle response nutsty?
i threw the timing light aside and slowly added more timing till it ran good and didnt ping. now, all mine does is destroy tires at an alarming rate
and as for the egr problem, i threw my egr in the garbage. problem solved.
Post by 79turbostang on Nov 5, 2009 22:37:04 GMT -5
I though it was my clutch slipping again it makes all this noise but i really doesn't pull. i wish my car would eat the tires off of it I'm in Chicago right now but when i get home ill be working on it again and let you all now whats up
