Post by richter888 on Nov 4, 2009 8:05:41 GMT -5
At this moment I can't physically sell anyone the car since I am stuck in the desert right now. I wont be back until Feb. I just want to see if there is anyone interested in the car. I'm located in Tampa Florida. Here goes...
I currently own an 89' 2.3 turbo mustang. Motor came out of an 87 tcoupe. Head was mildly ported with crane stage 1 roller cam with esslinger followers. .100 oversized ss valves from racer walsh 3-angle valve job with bronze valve guides. ARP head studs. 190lph fuel pump. xspower center mount header with a t4/t3 hybrid turbo with .52 ratio in the compressor side and .42 on the hot side. SS oil feed and return lines. I have a volvo radiator and intercooler with all piping installed. I have an xtra lb3 computer(currently a la3 computer is installed). I also have an extra valve cover from a SVO that says Ford 2.3 turbo fuel injection. SVO flywheel(installed). Gilmer boost control with switch that controls a solenoid for 2 boost settings(currently 7psi to 16psi). I also have 2 xtra and still good factory exhaust manifolds and the oil return line for ihi equipped motors. Also has adjustable cam gears from esslinger with round tooth type. I also have 38mm external tial wastegate installed.
Thats nothing yet. Four wheel disc brakes from 99+ mustang(2 pot pbr alum calipers in front) with 99 mustang brake master cylinder. Wilwood brake proportioning valve for the rear brakes. 5-lug swap with 95 15" stang wheels. 7.5" rear end with 3.55 rear gear ratio and limited slip with an aluminum driveshaft. Car was converted to 5-speed with svo transmission. Car has subframe connectors welded as well. Canuck Motorsports lowering springs(1.5 front and 1 in back). Caster/camber plates.
The bad:
Car is really ugly! The paint is faded and has the usual rust spots on the fenders and doors and some dents here and there. I coated most of the engine bay with POR 15 rust protection, but its really ugly. Interior is horrid though its manual windows with power locks. Hatch is rusted. I highly recommend putting a factory manifold back on as the turbo is way too big for a center mount header. I can do this for you for free. It doesnt take long. Car smokes due to valve stem seals. Roughly 115k miles on the engine, 220k on the chassis. Windshield also has a 2ft crack in it.
A 40bob log header would be better, but since i lost interest in this car and i want to get into the modular motor crowd.I am currently in the desert courtesy of our military. I wont be back until FEB. If you can wait.
Car has tons of good stuff. Askin $2250. I probably left some other good things out, but i cant remember everything i put on the car. Drives fine and gets around 23-25 mpg highway.. RUNS PREMIUM ONLY! I had to hard wire the premium switch. I also have a good 84' 300zx turbo parts car. I'm really curious to see if anyone is interested. I cant really provide any pictures since I'm stuck here the desert. I am keeping at least one of my turbo manifolds so i can put another one together if i want later. Throw me an offer.
The bad:
