codes
Nov 7, 2009 19:22:45 GMT -5
Post by denz on Nov 7, 2009 19:22:45 GMT -5
81,82,27 can you help me understand these codes more or less explain them to me. i ran codes to day and this is what came up.
codes
Nov 7, 2009 19:37:04 GMT -5
Post by merc460 on Nov 7, 2009 19:37:04 GMT -5
27 is a VSS problem 81 is a boost controler solenoid 82 EDF signal wire shorted to ground
codes
Nov 8, 2009 0:38:35 GMT -5
Post by denz on Nov 8, 2009 0:38:35 GMT -5
merc good to here from you again, so 27 is the sensor on the trans at the speed o cable right. what is edf? thanks denz
codes
Nov 8, 2009 10:14:12 GMT -5
Post by merc460 on Nov 8, 2009 10:14:12 GMT -5
The sensor at the trans is the VSS. The EDF is the Electro Drive Fan it turns the low speed fan on and off, the EDF relay is part of the IRCM. What ECU are you using ?
codes
Nov 8, 2009 11:34:34 GMT -5
Post by denz on Nov 8, 2009 11:34:34 GMT -5
la3 with self wired fans i could not get them to come on with stock wiring.
codes
Nov 8, 2009 11:41:06 GMT -5
Post by merc460 on Nov 8, 2009 11:41:06 GMT -5
Whats the problem you got a check engine light?
codes
Nov 8, 2009 13:04:49 GMT -5
Post by denz on Nov 8, 2009 13:04:49 GMT -5
no light, just wasn't sure if any of these codes would put it in limp mode. so i was just trying to eliminate them. one prob is that it seems to run better some days than others. some time it pulls hard in third and some it falls flat.
codes
Nov 8, 2009 13:11:30 GMT -5
Post by merc460 on Nov 8, 2009 13:11:30 GMT -5
Just checking because I also run a LA3 and I have those codes as well. I don't use the VSS and or factory boost controller and I have no real issues. My fan runs through the factory mustang wiring and I don't use the IRCM. Those codes are typical swap codes.
codes
Nov 8, 2009 15:11:10 GMT -5
Post by denz on Nov 8, 2009 15:11:10 GMT -5
cool thanks merc do you know what tps should be used with a 94-95 stock throttle body swap. can i use the one on the 94 t/b or do i have to adapt mine.
codes
Nov 8, 2009 21:06:15 GMT -5
Post by Stinger on Nov 8, 2009 21:06:15 GMT -5
You either make an adapter plate for the stock 2.3 TPS or run the 95 5.0 TPS. It will hit the egr bump on some intakes though so in that case, I believe there is an Escort TPS that bolts onto the TB and points up instead of to the side when bolted on.
codes
Nov 9, 2009 10:23:56 GMT -5
Post by merc460 on Nov 9, 2009 10:23:56 GMT -5
I run a Tempo TPS but I don't have an EGR bump. You will also need to splice a TPS plug into the harness as it is different that the factory 2.3 TPS plug. Also some of the 3.8 and 3.0 V6 used a 90 degree TPS also
codes
Nov 9, 2009 21:18:25 GMT -5
Post by denz on Nov 9, 2009 21:18:25 GMT -5
ya i made a plate and it allowed it to move, so i tried to run the 95 one and it would not work because the throttle would not turn it till it was half open. so i made a better plate and prob solved. is it wrong that mine seems to run better at .96 than .94 and some old 5.0 books say to set it ats close to.99 as you can. what does this have to do with the way it runs. i thought it was just for better response.
codes
Nov 9, 2009 22:01:47 GMT -5
Post by Stinger on Nov 9, 2009 22:01:47 GMT -5
We typically say to set them in the .90-.95 range so I'm not surprised at all.
