Post by Detroitthunder87 on Nov 15, 2009 22:14:59 GMT -5
Stinger I was wondering if the your oil feed line fits the ihi turbo? Thanks! ;D
Post by Stinger on Nov 15, 2009 23:42:28 GMT -5
Yes, as long as you use a 45 degree fitting at the turbo instead of the 90 that is supplied.
Post by shorangerbird on Dec 18, 2009 10:59:10 GMT -5
-this is just what i need to know. just got a line to use on my IHI, and was wondering where can you find the 45* fittings or what the thread size/pitch is to make an adapter work. have checked part stores and Home Depot/Lowes. no luck yet...... any suggestions? ?
Post by Stinger on Dec 18, 2009 16:25:44 GMT -5
Just get a straight fitting then, it will raise the 90 high enough to clear the backing plate.
