Post by cjdavid on Nov 18, 2009 9:42:08 GMT -5
WE HAVE AN HX35 THAT WE ARE GOING TO PUT ON OUR 2.3. IS THERE A WAY TO TAKE OFF THE EXHAUST SIDE HOUSING SO WE CAN KNOCK OUT THE SPLITTER?
Post by Stinger on Nov 18, 2009 13:44:05 GMT -5
Yes, remove the v-band clamp and pull it off.
soul
Post by soul on Nov 23, 2009 16:11:36 GMT -5
The exhaust side has 4 bolts holding it on on mine, (big clamp on the intake side) it will be hard to remove best advice I have is soak it in wd40. You can make a spreader out of a bolt a nut and an oversized not so that when you loosen the correct size nut it pushes the head and over sized nut against the housing to push it apart.
