Post by 03mach1 on Nov 18, 2009 10:01:57 GMT -5
i have a 84 mustang svo what all do i have to do to put the drive tran in 93 4cyl mustang
Post by merc460 on Nov 18, 2009 10:36:57 GMT -5
Start with the FAQ and then all the swap info on Stingers web site.
Post by 03mach1 on Nov 18, 2009 11:12:27 GMT -5
what all do i need to do the swap that what im asking
Post by merc460 on Nov 18, 2009 12:49:29 GMT -5
Post by 03mach1 on Nov 18, 2009 13:44:36 GMT -5
do i need the 87-88 t/c computer or can i use the 84 svo one
Post by Stinger on Nov 18, 2009 14:10:45 GMT -5
You need to read the 91-93 swap page linked to above. ALL of the questions you need are answered in there if you read it. The 87-88 TC computer is a L series (LA3, LA2, 8UA, LB3, etc). You can't change to a different ecu than the swap page lists without ignoring the swap page and figuring out the wiring your self because they are not nearly the same.
The 87-88 TC ecu is used because it is the best 2.3T ecu available.
Post by 03mach1 on Nov 18, 2009 15:23:08 GMT -5
thanks stinger
Post by 03mach1 on Nov 19, 2009 10:00:42 GMT -5
i have a another problem im trying to get the svo running its getting gas and spark and it trys to start but will not any help
Post by Stinger on Nov 19, 2009 13:15:54 GMT -5
Scan codes, verify cam and ignition timing.
