Post by 03mach1 on Nov 19, 2009 12:05:46 GMT -5
the 84 svo i have has gas and spark trys to start but will not has a new 255 pump any help thanks
Post by Stinger on Nov 19, 2009 13:18:59 GMT -5
Scan codes, verify cam and ignition timing.
Post by 03mach1 on Nov 19, 2009 13:26:40 GMT -5
it ran when parked hasent been started in 6 years
Post by Stinger on Nov 20, 2009 0:56:03 GMT -5
Fresh fuel? Do you have proper fuel pressure or just a little fuel pressure?
Post by 03mach1 on Nov 20, 2009 11:11:32 GMT -5
i put a 255 pump and fresh gas what should the fuel presser be thanks
Post by Stinger on Nov 20, 2009 13:15:33 GMT -5
Fuel pressure should be about 38psi key on engine off...anywhere in the 30-40psi range is fine initially though, just make sure it's not 5-20psi.
Still should check codes and cam/ignition timing.
