X-RAT
Boosting 15 psi
Post by X-RAT on Dec 15, 2009 18:49:13 GMT -5
anyone have pictures or a explanation on how to hook up a manual boost controller on a 88 merkur xr4ti with a auto trans. Im still running a stock setup with the T3 turbo hooked up to the boost controller solenoid. Right now it's controlled at 10-12psi. I'm planning to run 15-17psi. Im not sure if running the automatic ECU would be interfering with my desire but if anyone has the answer please respond thanks.
Post by Stinger on Dec 16, 2009 12:34:45 GMT -5
It depends a bit on what type of boost controller you use but basically, you just bypass the stock controller so you have the line coming from the compressor housing outlet to the new controller, then out the controller to the wastegate actuator.
