Post by ranger87 on Apr 5, 2020 0:37:45 GMT -5
Looking to figure out what cam might work best for my build its semi stalk has adjustable fuel regulator,fmic,aem fuel pump.going to eventually have upper and lower intake gutted rotated, header, turbo, injectors and the pimp ecu.not sure what to start with first either but would like to figure out a good cam for this little 4x4 thank you
Post by Stinger on Apr 5, 2020 2:06:36 GMT -5
What's the intended vehicle usage and do you prioritize tq or hp (low rpm or high rpm power)?
Any plans to port the head?
Power goals?
Post by ranger87 on Apr 5, 2020 13:23:43 GMT -5
I definitely want to have tq on the lower end but have the hp when I need it,this will be a daily but will need to be able to go on some 4x4 trails. close to 300 would be awesome,i do have a extra motor could do it if i need to 250-300hp would be good
Post by Stinger on Apr 5, 2020 14:58:50 GMT -5
A Ranger cam is fine. It certainly makes torque but don't expect it to do anything positive over 5000rpm unless you mess with cam timing (which will trade tq for hp).
A Bo 1.1 or 1.5 cam will make more power everywhere but it's obviously more expensive so I can't make that decision for you.
Post by ranger87 on Apr 5, 2020 17:46:46 GMT -5
OK thank you for the information that helps me a ton
