Post by strangesvo on Apr 7, 2020 19:37:52 GMT -5
5.8 95 Bronco auto trans. This will be a mild build, not looking for high HPs just want a good running truck. After researching a little information it looks like it would be a xsShift. Just a couple general questions: Would it likely need high Impedance injectors? Would have to get wideband O2 sensors as well, would they mount in the same location as the stock O2 or do they need to be down stream a little further. The goal is to have a nice running engine that can be tuned without having to do to much work or break the bank. Hoping to use the stock harness too. As much plug and play as I can get....
Thanks for the help.
Post by Stinger on Apr 7, 2020 21:03:54 GMT -5
They have to be high impedance injectors.
Wideband can go in the stock location for n/a applications.
Stock harness is good to go with just a few pin changes.
