Post by kevinl1058 on Aug 3, 2020 11:18:15 GMT -5
With my center mount manifold the compressor housing clearance # with the #1/#2 cylinder plug wires are going to soak up a lot of heat. Any plug wire kits out there with 45degree plug boots?
Post by Stinger on Aug 3, 2020 14:21:30 GMT -5
Just use plug wire clips that allow you to pull the slack out of them. You can put a 90 degree end on #1 if you want. Motorcraft plug wires come with a spare 90 degree boot on the extra coil wire they send.
Post by kevinl1058 on Aug 11, 2020 10:41:05 GMT -5
I trimmed a little of the straight boot end as well the clips.
