Post by Seth Watkins on Sept 11, 2020 17:36:02 GMT -5
I have a 1996 f150 and I’m looking to use one of your PiMPxs controllers to run the 347 I’m putting in the truck. I was wondering if the Ron Francis PM-75 wiring harness would be compatible with your xs controller specifically with the sequential fire injection
Post by Stinger on Sept 11, 2020 19:28:06 GMT -5
Post by Seth Watkins on Sept 12, 2020 20:43:15 GMT -5
Also on an alternative could I modify my stock harness to work with the xs? I know that the 96 is obd2 and I’m almost certain it is a sequential fire system. Also what would be required in the modifications?
Post by Stinger on Sept 12, 2020 20:56:42 GMT -5
The ECU connector is different and yours is 100 pin vs PiMPxs is 60 pin. So while it "could" be modified, you'll be modifying a LOT of wires so I wouldn't suggest going that route unless you're good with wiring, have lots of free time, have access to a junkyard you can grab the correct connector and a portion of the old style harness to connect yours to, and can't afford a new harness.
