Post by ranger87 on Sept 13, 2020 15:33:22 GMT -5
at first I thought it was the gauge, cause up until this point I've had no issues with fueling. ive got a brand new aem hp fuel pump new lines all the way to the fuel filter its had on about 6 months a new fpr of your site i got 4 or 5 months ago also. So when reving the engine it barely moves at all. as of now i replaced the fuel pressure gauge that's off the rail ive got almost 20 psi vacuum kinda at a loss for why and before I start just buying new parts and randomly take things apart if anyone has had this type of issue thanks for the help in advance 2.3t 87 ford ranger
Post by ranger87 on Sept 13, 2020 17:40:21 GMT -5
"Update" replaced the kirban fpr with a stock one new out of the box and still no pressure actually more like 5 psi on the gauge not even sure how its running cant touch the throttle or it dies still i guess pulling the tank and seeing if it the fuel pump is next
Post by Stinger on Sept 13, 2020 20:27:44 GMT -5
It's likely you'll find the hose that goes from the pump to the pickup tube is split or slid off or something.
Post by ranger87 on Sept 13, 2020 21:08:18 GMT -5
I hope its that easy it does like to fight me every step one thing happens park it and then fix it then something else happens lol
Post by Stinger on Sept 13, 2020 22:28:52 GMT -5
Once everything is brand new it will break slightly less often.
Post by ranger87 on Sept 14, 2020 10:20:04 GMT -5
Its pretty close to brand new now its going to be awesome when its off the jack stands again lol
