Post by Stinger on Mar 18, 2010 22:37:39 GMT -5
This is for those running the 60mm Super Coupe/94-95 5.0 Throttle Body on a 2.3 engine.
The problem with the factory TPS for this throttle body is that it hits the EGR mounting tab on the upper intake. Those who don't want to cut off the EGR and weld the hole shut, this is the solution:
The only one I've found that points up and has proper tab orientation is this one:
Application: 1990 Ford Tempo 2.3
OEM #'s: E83F- 9B989- AA; E83Z- 9B989- A; F1DF- 9B989- AA; F1DZ- 9B989- A; F1DZ- 9B989- AB Duralast #: TPS216, $25.99 - 2yr Warranty Borg-Warner #: EC1095, $48.99 - Lifetime Warranty Motorcraft #: CX-1415
Post by Stinger on Mar 18, 2010 22:53:31 GMT -5
This is what it looks like:
Post by denz on Mar 18, 2010 23:15:16 GMT -5
for this i would have to change my harness plug? and does this get rid of adapter plate?
Post by Stinger on Mar 18, 2010 23:20:58 GMT -5
Correct, you need the newer style plug...91+ Mustangs already have the newer plug.
Slotting the holes in the throttle body so it bolts to the intake gets rid of the need for an adapter plate.
Post by denz on Mar 19, 2010 15:17:22 GMT -5
what i ment is adapter plate on tps i had to make to run my stock one on my t/b. so this is a direct bolt on.
Post by Stinger on Mar 19, 2010 18:02:15 GMT -5
Oh, it eliminates that too...just bolt it on and grab the newer style plug and wire it in.
Post by denz on Mar 19, 2010 19:55:46 GMT -5
im on it mine is always moving.
Post by denz on Mar 25, 2010 20:47:36 GMT -5
stinger got one do you have wire instructions? and how did you make it adjustable or you set it and forget it.
Post by Stinger on Mar 25, 2010 22:20:29 GMT -5
Post by denz on Mar 25, 2010 22:27:10 GMT -5
this works thanks stinger.
Post by 93lxturbo on Apr 26, 2010 20:19:00 GMT -5
i got this tps and the lowest it will go is 1.65v and will only go to 4.75v wide open.. this is with the sc tb
Post by Stinger on Apr 26, 2010 23:28:32 GMT -5
4.75 wide open is typical. If it won't go low enough at idle and you've already loosened the bolts and rotated it to use the slack in the bolt holes to your advantage, the next step would be to slot the mounting holes to get more movement out of it.
This is all assuming your throttle blade is all the way shut. I've seen some of those throttle bodies have the stop screw adjusted too far open and it holds the blade open a bit which would also make the TPS read too high.
Post by cjdavid on Oct 14, 2011 19:15:36 GMT -5
So if I read this correctly, If I have removed the egr and welded it shut, I will be able to just plug into the 5 oh TB without changing the conector?
Post by Carl on Oct 16, 2011 18:09:22 GMT -5
From what I see on the connectors you should be able to do that.
Post by Stinger on Oct 16, 2011 22:17:43 GMT -5
So if I read this correctly, If I have removed the egr and welded it shut, I will be able to just plug into the 5 oh TB without changing the conector? Depends what car you are running it in (what the factory TPS connector is).
