Post by johnmnhoj on Feb 4, 2021 14:00:11 GMT -5
The bore size listed on the webstore are the FINISHED bore size, correct? I have my block bored and honed to 3.810, than I order the .030 piston/rod kit from you ?
Thanks.
Post by Stinger on Feb 4, 2021 14:47:41 GMT -5
Correct.
Post by johnmnhoj on Feb 4, 2021 21:41:10 GMT -5
Post by tutulate on Feb 6, 2021 23:18:48 GMT -5
Along the same line of CP pistons, what is the proper ring clocking? The instructions only address the top and bottom oil rails be 180* apart, but they don't mention the two compression ring clocking in relation to the wrist pin or front of engine. <iframe src="//remove.video/pblock" style="width:0;height:0;display:none;"></iframe>
Post by Stinger on Feb 7, 2021 3:34:58 GMT -5
Just don't line them up with any other gaps. The rings will rotate over time so the exact location doesn't really matter as it will change anyway. Just make them not the same so there is no chance they rotate together.
Post by tutulate on Feb 7, 2021 10:06:18 GMT -5
Thanks!
