Post by majbooth on Feb 8, 2021 1:12:42 GMT -5
I just received my Pimpxshift for my F-150 and had initially decided to go w/the Crane Cams 364211. I've since changed my mind and decided to go w/an Isky custom grind. My main concern, which might be a little too late at this point, is that my new cam has a 108 LSA for the lumpy idle even though the powerband is 1500-5500. My question is, can the Pimpx ecu be tuned to efficiently run a cam with that low of an LSA?
Post by Stinger on Feb 8, 2021 2:07:46 GMT -5
It's fine, the ECU has no limitations as far as cam specs go.
Post by majbooth on Feb 8, 2021 9:47:23 GMT -5
AWESOME! So the base tune supplied on the thumb drive will still work even though it's a different cam then what I said I'd be using when I placed my order initially, correct?
Post by Stinger on Feb 8, 2021 14:35:40 GMT -5
The duration @ .050" is what determines what base tune you get. Looks like the Crane is a baby cam (basically stockish). I'd need to know the duration @ .050" of the custom cam and whether your base tune name has "stock" or "mid" in it to know if it's right or not with the new cam.
