Keycode
Apr 20, 2021 20:39:16 GMT -5
via mobile
Post by boostwildfordays322 on Apr 20, 2021 20:39:16 GMT -5
I need to purchase a key code for software? thanks my 3 key codes got used up long story short just need to know where to purchase thanks
Keycode
Apr 20, 2021 20:45:27 GMT -5
Post by Stinger on Apr 20, 2021 20:45:27 GMT -5
You can use it more than 3 times as long as we don't suspect you're abusing it or sharing it.
Keycode
Apr 20, 2021 20:58:37 GMT -5
via mobile
Post by boostwildfordays322 on Apr 20, 2021 20:58:37 GMT -5
Thanks man I will give it a try no it was not abusing one laptop went bad would not boot up. The 2nd laptop had the code and then lost all files and had to reinstall windows and then use that code and then it also had battery issues and I just purchased a good expensive laptop bc I got tired of laptop issues lol!
Keycode
Apr 20, 2021 21:02:06 GMT -5
Post by Stinger on Apr 20, 2021 21:02:06 GMT -5
Should be fine then.
Keycode
Jun 20, 2021 11:54:51 GMT -5
via mobile
Post by boostwildfordays322 on Jun 20, 2021 11:54:51 GMT -5
So I finally got back around the laptop and every time I open the tuner studio it goes to the EFI Analytics website trying to get me to purchase the software?
Keycode
Jun 20, 2021 11:57:35 GMT -5
via mobile
Post by boostwildfordays322 on Jun 20, 2021 11:57:35 GMT -5
Also I try to enter the Coupon code and says already been used!
Keycode
Jun 20, 2021 18:01:16 GMT -5
Post by Stinger on Jun 20, 2021 18:01:16 GMT -5
The coupon code has already been used...you used it when you did the original install to register the software to your name.
What you're confusing is the coupon code (which we supply on the USB) vs the license code (which you get emailed to you from EFI Analytics after you register the software on their site using the coupon code we gave you). One is a coupon, one is a license. They aren't interchangeable.
If you read the last paragraph of the file on the USB that has the coupon code in it, it shows you the link you use to get that email re-sent, if you didn't save the original email.
Keycode
Jun 20, 2021 19:48:09 GMT -5
via mobile
Post by boostwildfordays322 on Jun 20, 2021 19:48:09 GMT -5
I did that and still says the same thing!
I have copy the link in the file and still says the same thing!
Keycode
Jun 20, 2021 20:39:08 GMT -5
Post by Stinger on Jun 20, 2021 20:39:08 GMT -5
You're not understanding what I'm saying. There is nothing about the process I'm describing that will tell you it's already been used because the thing I'm describing has nothing to do with the coupon code, or something being "used" as it is used for people in your exact position (previously registered, needs the code re-sent for a new computer). This is the last paragraph in the file that came on the USB that had the coupon code in it: If you ever need your registration number again (new computer for instance) and find you didn't save the original email, you can have the email re-sent by using this link: www.efianalytics.com/register/resendRegistrationEmail.jsp You click that link above, enter your name/email that you originally used to register it years ago, follow the directions and it will re-send you the registration code (keycode as you call it).
Keycode
Jun 20, 2021 21:48:11 GMT -5
via mobile
Post by boostwildfordays322 on Jun 20, 2021 21:48:11 GMT -5
I got it now thanks sorry the file we was talking bout did not have it for some reason but thank you and have a great day!
