Post by laredo on Apr 23, 2021 13:25:52 GMT -5
Hi Shannon, How long are the "BoPort header" turbo drain hose and supply hose. The twin scroll header is quite a bit different, and I'm mounting to a Borg-Warner EFR. Need to know if it will reach. Then I'll worry about fittings.
Post by Stinger on Apr 23, 2021 16:46:10 GMT -5
I'm out of town and can't check but it goes "out and around" and then dips in between ports 3 and 4 so it should be fine regardless. We can also make them whatever length is requested.
Post by laredo on Apr 26, 2021 17:29:44 GMT -5
Sounds good. If that works out I'll add it to my downpipe order - gotta get a new one those also to mount to the EFR.
Post by laredo on May 12, 2021 18:56:18 GMT -5
Got my downpipe ordered. We’re you able to get a measurement on that turbo drain?
Post by Stinger on May 12, 2021 21:32:55 GMT -5
I didn't have any intention of posting this info to the forum. It's likely more useful if you measure what you think you need. We like to use a 90 on the block end (45 deg fitting with threads facing straight up out of block, then 90 facing passenger side, then go between the header tubes and loop around header and up towards turbo and then have a 45 degree fitting at the turbo to get it to clear the header flange.
