brad
Boosting 15 psi
Post by brad on May 7, 2021 11:27:36 GMT -5
See my mods below. I'm looking to support 300-350hp and maintain good drivability and idle. More street than strip. I don't know whether to skip over the 48 lb/hr injectors (FID 500) and go with the 69 lb/hr injectors (FID 780). Thanks.
2.3L Turbo Coupe with stock brown tops
Stinger PiMPx
255lph Walbro
Gnari manifold
Stinger FMIC
Garrett T3/T4 50 trim .63 AR
Stinger 3 inch downpipe and dual 2.5 Magnaflows
External wastegate
Head, cam, and intake are all stock
Post by Stinger on May 7, 2021 14:26:36 GMT -5
The 500's would be borderline too small at stock fuel pressure and the high side of your power goal (assuming that's power at the wheels) so you'd either be looking at the 780's, or the 60lb Deka injectors. Both will be fine as far as idle/drivability is concerned.
brad
Boosting 15 psi
Post by brad on May 7, 2021 14:41:49 GMT -5
Thanks! What base pressure should I run the 780's at? I'm using the Kirban regulator if that matters.
Post by Stinger on May 7, 2021 15:17:00 GMT -5
Standard pressure for rating injector flow is 43.5psi.
