Post by eclipceccm on Aug 22, 2021 14:23:27 GMT -5
Okay, I have a 96 Ranger original 2.3L and I also have a 1985 Turbo Coupe engine. Is there any way to keep the obd2 setup while running the complete 85 engine? Or would it be easier to run the obd1 setup?
Post by Stinger on Aug 22, 2021 23:07:22 GMT -5
To do it with OBD-2 you have to tune the stock ECU with a flash tuner (SCT for example) or with a Quarterhorse chip. You also have to live in an area where they don't require emissions testing/visual inspection. The older Rangers are easier as there are harnesses, aftermarket ECU's, stock ECU's, etc. that work.
Post by eclipceccm on Aug 23, 2021 11:17:00 GMT -5
Thank you for the quick reply. I was going to get the obd1 computer and the stand alone harness (bare bones) just to run it for the time being. I have yet to hear this engine run so I want to do that before I dive head first into your full harness to just run obd1
Post by Stinger on Aug 23, 2021 11:39:23 GMT -5
Some of this decision comes down to whether you're planning to run the Ranger dual plug ignition, or convert to the distributor and such from the turbo engine. There are no dual plug harnesses available in the aftermarket but there are harnesses for the distributor setup.
Post by eclipceccm on Aug 23, 2021 12:43:22 GMT -5
Wanted to run the 8 plug ignition setup on the 4 plug head. I’ve heard it’s been done. I also have a 91 ranger that’s a parts truck that has the dual ignition with one of those in the same location as the distributor. What would I need to add to the obd1 harness from the turbo coupe to run that? I’ll just stick with obd1.
Post by Stinger on Aug 23, 2021 13:02:52 GMT -5
If you're wanting to use a new harness, running a distributor would be WAY easier.
If you want to use a new harness and retain the distributorless ignition system (minus one coil) then you've got to modify the new harness to connect to the DIS module (two connectors), add the crank sensor wiring, and add the cam sync wiring (that's the dummy sensor in the distributor hole on your 91, or the sensor on the auxiliary shaft on your 96). This is not a common process so you'd basically be "on your own" for the wiring mods. I've got diagrams for the 91 dual plug system (stock) that I could send you to assist a bit.
Post by eclipceccm on Aug 23, 2021 13:26:40 GMT -5
I also have the complete harness for the 91
Post by Stinger on Aug 23, 2021 13:33:04 GMT -5
The 91 harness with the DIS ignition and our PiMPx ECU is basically a plug and play deal.
Post by eclipceccm on Aug 23, 2021 13:37:34 GMT -5
Can I use the 91 ranger ecu and tune it for the turbo setup? Your pimp looks great and easy but I don’t have the money right now.
Post by Stinger on Aug 23, 2021 19:07:27 GMT -5
If turbo swapping the 91 Ranger, if you can't afford a PiMPx then you'd need to get an 87-88 Turbo Coupe ECU, Air Meter, and Injectors and then use that to control the engine. You may be able to use a Quarterhorse chip to tune the Ranger ECU (if someone has a bin file for it) but there isn't much support for that method and trying to tune something without support can be pretty daunting.
