84 SVO
Jan 13, 2022 20:26:01 GMT -5
Post by aldridgesvo on Jan 13, 2022 20:26:01 GMT -5
Are there specific instructions for installing this setup in a 84 SVO? Im trying to figure out what jumpers I need in the ECU? How to wire the Spartan 2?
84 SVO
Jan 13, 2022 21:36:55 GMT -5
Post by Stinger on Jan 13, 2022 21:36:55 GMT -5
You didn't say what setup you're referring to but I'll assume it's a PiMPx?
Are you referring to something other than the Startup Guide that's on the USB thumb drive that comes with the ECU? Every step required for installation, including jumpers and Spartan 2 wiring are covered in detail in that guide.
84 SVO
Jan 13, 2022 22:18:20 GMT -5
Post by aldridgesvo on Jan 13, 2022 22:18:20 GMT -5
You didn't say what setup you're referring to but I'll assume it's a PiMPx? Are you referring to something other than the Startup Guide that's on the USB thumb drive that comes with the ECU? Every step required for installation, including jumpers and Spartan 2 wiring are covered in detail in that guide. sorry yes I have the PimpX v1.2.2 I'm just trying to figure out what jumpers I need to install. I have a stock SVO and I was told it has a slightly bigger camp and fuel injectors. I started wiring the O2 sensor in, what do I do with the blue and brown wire?
84 SVO
Jan 13, 2022 23:09:22 GMT -5
Post by Stinger on Jan 13, 2022 23:09:22 GMT -5
Check the "Mandatory Jumpers for Common Setups" section for the jumpers for your SVO.
If you've got unknown injectors, you'll need to measure the resistance of the injector (pin to pin on the injector itself) to see if they are low or high impedance.
Wideband wire colors that aren't listed aren't used. Only info you need is in the guide.
84 SVO
Jan 19, 2022 19:55:40 GMT -5
Post by aldridgesvo on Jan 19, 2022 19:55:40 GMT -5
Check the "Mandatory Jumpers for Common Setups" section for the jumpers for your SVO. If you've got unknown injectors, you'll need to measure the resistance of the injector (pin to pin on the injector itself) to see if they are low or high impedance. Wideband wire colors that aren't listed aren't used. Only info you need is in the guide. Okay I so the injectors ohmed out at 2.6, so they are low. Looking at the instructions are the only pins I need to install are JP2, JP19 on a stock setup? sorry fro all the questions. I'm not sure if my instructions are out of order or what, just trying to make sure everything is correct before I try it.
84 SVO
Jan 19, 2022 21:03:53 GMT -5
Post by Stinger on Jan 19, 2022 21:03:53 GMT -5
Page 4 of the Startup guide:
Common Setup Examples for Mandatory Jumpers Here are some examples of common setups showing which jumpers are mandatory to run the engine. Other jumpers will still be needed if you’re wanting to control anything that doesn’t affect engine operation (fan, table switching, boost control, launch control, etc.) and those jumpers are shown in Jumper Table below as well as the Optional Jumpers on the following pages:
--2.3 Turbo Batch Fire with TFI (Distributor) or DIS Ignition & Low Impedance Injectors: JP2, JP19 (pins 2-3 – 12v).
