Post by bgpickle on Apr 28, 2010 8:30:00 GMT -5
stinger i have a 1984 svo that i am building. it will be a daily driver and street/ weekend drag racer. is the 84 intake good with some work or should i look for a different one? the same goes for the exhaust manifold? if so which ones are best with or without porting?
Post by Stinger on Apr 28, 2010 10:58:41 GMT -5
They are pretty much equal as far as the intakes go. Exhaust manifolds are a different story, there are "E3" and "E6" versions. The E6 came in 86 and was a replacement for the crack prone E3. It also flows much better. They can be identified by the last two digits in the part number cast into them (as well as a few other ways).
Post by bgpickle on Apr 28, 2010 12:35:42 GMT -5
thanks! should they both get ported. the 86 style intake looks like it flows more then the 84, is that true? i have time to look for both, unless u have them for sale.
Post by Stinger on Apr 28, 2010 14:06:48 GMT -5
They both flow similarly when ported and when stock, clearly porting increases flow for either one, though they won't increase hp a ton if the head doesn't flow as much as the intakes.
I've got a ported early style intake that came off my SVO that's also been modified for use with a 65mm tb.
Post by oneowner88lx on Apr 28, 2010 18:28:02 GMT -5
The E6 manifolds definately benefit from porting.
Post by bgpickle on Apr 28, 2010 20:56:17 GMT -5
stinger email me so we can talk about that intake! my e3 is stock and not cracked, should i just port that one or look for a e6 instead? which one will help out the most, i don't want to port the e3 if it is not worth it i will just look for a e6 if it better? i am sending the svo head to bo-port for a valve job and a stage 1 port and polish. i just want to do it once, and your advice is priceless! thanks
Post by Stinger on Apr 28, 2010 21:55:13 GMT -5
A ported E3 "might" flow as well as an E6 and will crack soon, definitely start with an E6.
You can see a few pics of the ported inline intake in the thread about my SVO on here in the customer cars section, first few pages show the silver inline intake. That is it. You can pm or email me if you are interested.
Post by oneowner88lx on Apr 29, 2010 18:51:29 GMT -5
