Post by cjdavid on Apr 30, 2010 15:49:31 GMT -5
ANYONE HAVE ANY IDEAS ON HOW TO "UNSTUCK" AN H35 TURBO ON THE HOT SIDE. WE HAVE SOAKED THIS THING WITH WD FORTY SO MUCH THAT THEIR STOCK SHOULD HAVE GONE UP. WE'VE EVEN USED THE HANDLE FROM ONE OF OUR FLOOR JACKS FOR LEVERAGE BUT IT HASN'T BUDGED. ANY HELP APPRECIATED
Post by turbo23240sx on Apr 30, 2010 18:29:12 GMT -5
Try puting heat to it with a small torch and knocking it free with a hammer carefully. I always seperate the two and then clean the rust off and get the clocking close and reinstall with some anti sieze or some lube so it will turn easy.
Post by Stinger on Apr 30, 2010 22:58:28 GMT -5
That's pretty much the way to go....well that and a big hammer anyways.
Post by cjdavid on May 1, 2010 12:14:31 GMT -5
Ok will try doing that. Thanks for the replies. Will let you know how it goes. David
Post by cjdavid on May 1, 2010 12:33:25 GMT -5
Since I will have it apart,(hopefully) Is there much benefit to gutting the hot side?
Post by Stinger on May 1, 2010 14:26:41 GMT -5
What do you mean?
Post by cjdavid on May 1, 2010 14:53:56 GMT -5
removing the split scroll
Post by Stinger on May 1, 2010 17:41:27 GMT -5
If you are running an external wastegate there is no reason to. If you are going to use the internal gate, it's mandatory.
Post by cjdavid on May 1, 2010 18:01:32 GMT -5
OK THANKS STINGER. WE ARE RUNNING AN EXTERNAL WASTE. i'M GLAD TO HEAR THIS...I'M TIRED OF PORTING.
