Post by xtcnagt on Mar 2, 2022 22:51:00 GMT -5
I ordered a 2.3 fuel rail but can't find what style the fittings are going into the rail ends. Are they ORB or taper/compression fit? Thanks
Post by Stinger on Mar 3, 2022 0:38:24 GMT -5
Post by xtcnagt on Mar 3, 2022 1:54:09 GMT -5
I did see the pic but I'm not confident and would like to order fittings. I see one side is -6 and one -8, do they need to be ORB or AN 37* flare internal rail fitting? Thanks
Post by Stinger on Mar 3, 2022 13:58:26 GMT -5
They are ORB.
You need to test fit for clearance before ordering as some applications are close enough to the alternator that you need to plug that end and use the aux port for the return line.
