Post by strangesvo on Mar 6, 2022 21:56:00 GMT -5
Sorry but I couldn't fine the answer in previous E85 posts. The fuel pump and bracket has that small Rubber S hose. What are others doing to replace this with a ethanol compatible hose? I hear rubber lines with ethanol are a no go. I don't want to complete this conversion and have to drop the tank again because that hose is trashed. That little hose is specific to that pump and bracket and is pre-shaped to make that bend.
Post by Stinger on Mar 7, 2022 11:41:40 GMT -5
Some rubber hose is ethanol compatible. There are also some plastic "crinkle" hoses used for that line. It's available in some Walbro install kits (not positive which ones).
