Post by boosted88 on May 13, 2010 11:42:40 GMT -5
ok so here is the run down. i took my old harness out of my car because they guy that did the swap did a very bad job as there was wires cut and it just looked bad. so i went to the junk yard and picked up a harness out of a 89 or a 90 mustang. my mustang is a 88 if that helps. so i got it out of the car and i sent it to a guy you pined and fixed every thing on it and did a very very very very good job on it. he labled every thing and i pluged every thing in that was labled. well i still had a few plugs that were not labled and i was told if they fit some where else plug them in. so i did, well i went to go start my car and i noticed my fuel pump was not turning on, so i checked every thing the ground ect ect. and then i seen if i has spark well no spark. what can cause this? ? i got brand new spark plug wires ect ect. but i got no fuel as well. so i check the fuse under my seat for the fuel pump and its was pluged in. i restarted the switch in the hatch for the pump and still nothing. what should i be looking at??? if you guys could help that would be cool. i got this on allfordmustangs.com as well. i would like to get as much help as i can. thanks guys
Post by Stinger on May 13, 2010 14:06:44 GMT -5
You can voltage to the pump, tfi, coil, or any of the sensors under the hood to make sure the harness is doing what it should. I would think the person that did the harness for you would be the ideal person to talk to though. How they could screw up a harness that only requires 4 wire changes is mind boggling though.
Post by boosted88 on May 13, 2010 15:25:40 GMT -5
the guy did a great job on the harness. i think i might have screwed things up. i am goin to double check every thing that i did. and i will update. i dont see my computer being bad as it worked befoir i switched the harness.
Post by Stinger on May 13, 2010 18:34:37 GMT -5
Just because it looked good doesn't mean it's right. There are no two plugs that will plug into each other that shouldn't be plugged into each other.
IF it ran ok before and IF the ecu is fine, then the harness is 99% the issue.
Post by oneowner88lx on May 13, 2010 19:01:53 GMT -5
The car did not run well at all, probably stuck in limp mode, with tons of codes. That is why he went with a different harness instead of trying to fix the on he had.
Post by Stinger on May 13, 2010 22:00:52 GMT -5
So what's the codes now?
Post by boosted88 on May 14, 2010 1:36:19 GMT -5
see this is the weird thing. i went to plug my code reader in and to turn the key to on and nothin. well if i turn the key all the way on like if i was goin to startit. then it will just stay beeping.... i dont know whats up? i got the upper and lower intakes from the tc and i was told some people run the stock N/A. but what wires should i look at for notgetting spark or fuel?
Post by boosted88 on May 14, 2010 1:40:15 GMT -5
i got a vid of what i got hooked up.... my youtube name is dirtdog16. its vid 199. hey 88lx did you check out the vid posted it on allfordmustangs.com. it sucks i am not good with a volt meter but i gess i will have to learn lol. but ya if you could check out the vid thanks guys
Post by Stinger on May 14, 2010 2:25:47 GMT -5
OK, so you're the same one that said: f* it i dont care. i am trying and trying, well you know what fuk it i am getting rid of the 2.3t and getting a real motor, f* this 4cyl nuts. this site is over rated i can go to the any other site and get just as much help if not more plus they are way nicer. this site is just full of di**s. my bad i dont know how to READ A VOLT METER HELL I "MUST BE A BAD PERSON" HE SHOULD NOT OWN A EFI CAR" well you know what fuel injetion SUCKS ANY WAYS. i thought this site was for help. all its ben is you guys calling me dumb well you know what there is way more sights out there than this one. And then you got banned... So now you are back with a new username and want us to help you after you said we are all Di**s and that you can get more help on other sites and such? Good luck with that one... My advice months ago was to sell the car, I still think it's the best option.
Post by boosted88 on May 14, 2010 12:00:15 GMT -5
ok well i did do 1 thing you said, and that was get my harness fixed, and i did. the problem i am having is when my old harness was hooked up, the wires were cut and i did not have any clue. there might have ben ends on some of those wires but the guy might have cut them off. i will say i was a richard. but you got to inderstang that, i was under alot of stress not with this car but will some other problems. you are saying to sell MY CAR because i ran in to a little road block? i dont think so. then you want to sell me a turbo and then you turn around and tell me to sell my car? ?? i am not calling any one out here. i am trying to get as much help as i can so i can learn. i dont got a nice shop, i dont got alot of money, and i dont got help, it's only me working on this car. if you dont want to help me thats fine. but i thought a forum was for help? was i wrong in asking for help here?
Post by Stinger on May 14, 2010 12:59:46 GMT -5
You didn't run into a little roadblock. You ran into a problem that has not been solved for 5 months and is above your ability to fix it because you aren't familiar with efi systems.
Without using a volt meter, you can't diagnose the fuel or spark issues to verify items are getting voltage, outputting voltage, grounded, etc.
Post by merc460 on May 14, 2010 14:04:43 GMT -5
Oh boy here we go again. what stinger said X2
Post by boosted88 on May 14, 2010 16:23:19 GMT -5
and what did i say??? i am learning... a friend knows how to read one. who cares if it takes me 5 years to get it done??? i am the one spending the money. no one else. if you dont want me asken ?'s on here then tell me??? i am sure there is a few people out there that are haven some problems as well.
Post by Stinger on May 14, 2010 23:49:30 GMT -5
I have no problems with people asking questions, I have no problems answering them. Unfortunately I can't fix cars for people though, only give advice. When the person asking for help doesn't have access to the diagnostic tools needed to solve the problem or lacks the mechanical fortitude to use the advice in an efficient enough manner to work through the problems, it's difficult or impossible to help from a distance.
Who cares if it takes you 5 years to fix it? Everyone who's spending their own time trying to help. By this point, all possible problems have been covered. These cars aren't rocket science. There can't be 5 months worth of possible problems. You need air, fuel (in the right amount), and spark (at the right time) to run perfectly. It's really as simple as that. If you are lacking one or more of those items, figure out why and fix it, done.
Typically banning someone from a forum (after several warnings) is a pretty good way of telling someone to not ask any more questions until 1) they've fixed the current problems or 2) they've gained enough knowledge to ask new and more in depth questions while providing detailed, useful, and accurate information about the problem, typically through electrical diagnostics (with a voltmeter).
Post by oneowner88lx on May 15, 2010 7:11:26 GMT -5
In this video the wire taped up running to the negative battery terminal. That wire goes to the positive terminal on the starter relay:
The big bunch of wires should run to knock sensor, TPS, IAC, oil pressure, and coolant temp for the guage.
