tinman
Post by tinman on May 21, 2010 15:54:41 GMT -5
when using the stinger tranny adaptor plate, do you need to install the factory v8 block plate also? do you use the stock pilot bearing?
Post by Stinger on May 21, 2010 16:45:39 GMT -5
Yes.
Only if you're using a 2.3 trans.
tinman
Post by tinman on May 21, 2010 17:13:24 GMT -5
rodger that! thanks
