Post by boostgobbler on May 21, 2010 23:25:04 GMT -5
due to lack of space i will need to reclock my center housing in such a way that feed and return lines wont be vertical, instead they will end up slightly vertical and the turbo is only oil cooled so will this cause a problem? if you need more info or pics let me know.
Post by Stinger on May 21, 2010 23:54:10 GMT -5
Garrett says up to 35 degrees of angle is ok...though I'd suggest you stay well under that. A little angle is fine though.
